Assistance Needed: EDC17C60 - Drivers Wish Table
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
1092 Vistas
Hello!
I hope this message finds you well. I'm currently working on an EDC17C60 ECU from a Peugeot 308 HDi with a 1.6L Diesel EURO6 engine. I've been trying to locate the drivers wish tables without success. Could it be possible that these tables appear differently in other brands compared to what was described in the course?
Interestingly, I also have a Seat Leon (VAG) File from a EDC17CP14, and in this case, I can locate the drivers wish table immediately. It appears exactly as described in the course.
I've attached the .ols file to this post, and I was wondering if any of you could help me find the drivers wish table for the Peugeot 308 HDi.
Thank you in advance!
  • WinOLS-Peugeot-308-Original-037985.ols.zip
Hi,
there are 6 drvers wish maps 16x16 iadress: 334132, 334332, 334532, 334732, 334932, 334B32
Values are in NM and factor is 0,0625.
RPM axis adress: 333EF2 factor 0,25
Pedal axis adress: 333F12 factor 0.0078125 values 0-100%
I have damos for EDC17C60.
