Idle control and decel stal issue with e-throttle
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
1892 Vistas
I have been watching the vids on tuning the vw corrado 1.8t plug and play link g4+. I have the exact same ECU in a AUDI S3 with a very similar setup.
I am more used to tuning haltech ecu systems rather than link, I am looking for a decal table for idle control as in the elite software you can set how much extra in % you want and for how long it will apply for, also long for it to be taken away to stabilise idle control. My issue is when blipping throttle engine just drops to low and will a lot of the time stall. My question is does how does the link ecu control this?
My fuel and ignition is all fine, also i have it running it in open loop idle to try and stop it stalling, also have wideband disabled just incase.
post screenshots of the tables you are looking at.
A log of the problem and a copy of your tune would be helpful.
