Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
I am rebuilding an EJ257 with the goal of achieving stock engine performance. I have installed King MB5382XPG main bearings and will be using a new Subaru factory crankshaft. The Subaru rebuild manual calls for oil clearance on the main bearings of 0.00039-0.0012” while King recommends 0.001” of clearance per inch of shaft diameter. Main journal diameter is 2.362” making a target oil clearance of 0.0024”, twice what the factory recommends. I measured with the bore gauge and found clearances between 0.0023-0.0026”. I’m wondering which guideline I should follow and if I go with the larger clearances should I use higher viscosity oil or perhaps a higher capacity oil pump?
Clearance depends significantly on what you're going to be using the engine for, and the power/torque expected.
This specific enquiry has come up multiple times - a simple search should narrow it down for your specific application.
You'll also want to make sure you don't set the engine up in a manner that you can't provide it with sufficient oil flow due to excessive bearing clearances.
