EMU Black with PRP triggers settings?
Comunicaciones CANBus decodificadas
983 Vistas
Hi there I am using the PRP triggers which I believe are 12-1. does anyone off hand know what the trigger settings on the emu you put in for primary and secondary triggers are? on a rb30/25 btw
thanks
Hey Joey,
PRP use 12 teeth on the crank trigger, some people grind a tooth and it become a 12-1 but the settings attached are for a out of the box crank gear with no modification.
The cam sensor bracket is slotted so the final settings will depend where it's set, you'll still need to put a timing light to confirm your base timing.
Hope it helps!
Frank
