Formula ks Pro general opinion + Modifications
Comunicaciones CANBus decodificadas
303 Vistas
Hi, as the title says for interest what is everyone’s general opinion of it? It picks up knock for sure but it also picks up EVERYTHING else in the background! It is quite difficult to hear knock, specially when so much is happening around you when tuning! I wonder if the circuit could be modified to cut the back ground noise down a bit? To be totally honest I was expecting it to be better than what it is, as said it detects knock, you have to have the volume up a fair bit, it’s actually quiet uncomfortable at times! Has anyone tried anything to make it better?
