R32 Skyline GTR with M130
Cableado práctico para deportes de motor - Nivel profesional
1566 Vistas
I am running an M130 ECU with the USA Drag firmware on my R32 GTR . Is there a way to use an aux output to mimic the TPS input signal for the TPS out signal required for the AWD system?
What does the "TPS out signal required for the AWD system" look like? If it's an analog voltage you are probably out of luck, but it a PWM at a fixed frequency, or a variable frequency then it might be possible.
From what I have found it is 2/3 of the TPS signal voltage that feeds the ECU. On the R34 GTR is a 1:1 of the TPS signal voltage that should also work. Factory spec says the signal is 0.4 to 4V.
I did find this: https://www.haltech.com/product/ht-038001-nissan-attesa-4wd-tps-adaptor/ that might work.
I use a voltage follower (an OP AMP configured at 1:1 gain) and connect the output of the TPS to it. It reproduce the TPS output voltage without messing with the signal to the ECU. Mine is basically the homemade version of the Haltech haha! Even on the R32 I do a 1:1 and never had problems.
I heard some use a PWM table with TPS as an axis to "recreate" the 0-5v signal, but I never done it myself.
Well, I learned something! If it were me, and I was doing it for a customer, I would use that Haltech part.
Thank you guys for the help!
