Fuel pump Recommendation
Módulo relevante: Fundamentos del etanol > Requisitos del sistema de combustible
576 Vistas
I have a 7.3L Ford Godzilla that was set up for a power adder. We dyno'd the motor at 712 NA. With a 3.0l Whipple with 93 Octane it should give us around 1100hp with 900 ish FTLB torque. on E85 racing fuel we should make in the 1500-1700 range. My question is this. Have you any experience or recommendation on the Fuel pump that would support that HP and Alcohol/Gas. I was going to run a flex fuel system with 2 tanks. A 15-20 gal 93 gas and a 5 gallon tank for the E85 racing fuel. I was wanting to run one pump with a switchable fuel log to both tanks. The motor is for a single cab short wheel base 4x4...Tanks would be in the bed!
I'd run the ID pump kit in the E85 tank: https://injectordynamics.com/id-bpc100/
And stage two basic walbro 274 pumps in the gas tank since they have built in check valves and to keep costs down.
