Mathmatical problem
1862 Vistas
Taking the same numbers
Bore 4 inch
Stroke 4 inch
pie is constant 3.142
3.142x (4x4)radius x 4(stroke) = 201.088ci
But in the example you gave the result is 50.27ci for every cylender
What is the correct answer?
Thank you
Bore = 4 inch diameter, divide that by 2 for radius.... however the correct answer is still 100.53 if you are calculating volume :)
