N/A Barra turbo conversion
3335 Vistas
Hi guys
I am collecting parts to convert my Barra into XD Falcon conversion
The engine will be rebuilt and running Garrett GT4094R CRG T4 manifold
will also be upgrading to billet oil pump gears and Crow valve springs.
I have been looking at some stainless int & exh valves
Looking for recommendations on brands or if anyone has used Mace engineering
Cheers
i cant help to much other than to say mace engineering have a very good reputation
Regards Ross
Thankyou for the reply Ross
The price from Mace is good
so I might go with their product
Seems like you're building a serious engine, not something I'm famiar with, but i would suggest you have an honest think about what you expect to end up running and build for that - cencentrating on the harder to reach parts first, rather than bolt-ons. You may be wise to do the rod/piston and studs bit before worrying about the top end, as the latter is easier to do and you will have the foundation to take the abuse power.
You may also need to have a good look-over over the transmission, etc - they may be OK for moderate levels, but if you're pushing it, you may need to rip it all out.
Basically overbuild for what you think you need at the moment - it cposts a littl emore initially, but generally a lot less than having to do it all over again.
'course, you could already have all that in mind.
Thank you for the reply
I am in new territory also but lucky to have a few friends with boosted cars and have been following other guys builds looking at what’s required.
I have been thinking about the rotating goodies probably going with Spool kit for that,just trying to get smaller bits and pieces as I am saving and spending abit at a time.
Items in the warchest I have already are Arp main & headstuds,billet oil pump gears,Crow valve springs,Turbosmart Fpr 1200 reg and 60mm gate,turbo is sorted too
IIRC, there was a series of videos HALTECH put out on modifying the Barra in stages - Ah, here you go - https://www.youtube.com/watch?v=8333N6AS440&list=PLY0xLKM0FbEzpFwUUwhJqlttsmD86fBqz
Awesome
Thankyou for that
