2020-2024 Toyota Camry TRD
Módulo relevante: Tablas del sistema de gestión del motor > Tablas de compensación
1699 Vistas
What does D3 Performance Pro tuner software ECU flash tables represent
currently from learning i have a maf sensor and tables.... to be continued
I suggest asking the software supplier for a specific list of software capability for the particular vehicle you're wanting to tune, or perhaps the software can be downloaded so you can see for yourself?
D3P PRO TUNER- what it has to offer/parameter
MAF TRANSFER- WITH 2 TABLES AND 2 GRAPHS
AIRFLOW CORRECTION
AIRFLOW CORRECTION 2
THIS PARTICULAR POST WAS ABOUT A SPECIFIC ONLINE COURSE FOR AN MAF SENSOR AND MAP SENSOR IN A REFLASH SOFTWARE FROM THE MANUFACTURER AND WHAT IT ALL HAS TO OFFER. IF YOU HAVE ALREADY PURCHASED THE COURSE FOR FUNDAMENTALS FOR EFI I HIGHLY RECOMMEND IT. I AM NEW TO THE INDUSTRY AND IT IS HELPFUL. TOPIC NOW MOVING FORWARD IN MY CHOICE. THANK YOU
