Compression ratio
Módulo relevante: Ejemplos resueltos > Nissan SR20VE > Paso 1: Preparación inicial
491 Vistas
When beginning a build and determining the compression ratio wanted for this application, how do you know what piston, connecting rod length, and head gasket thickness to use to accomplish this.
