K3VE trigger
1692 Vistas
Is there anyone who has a solid data on this engine setup ?
I am using elite 550 on this engine.
Runs well but hit limiter before 6500..
Like the ecu reads 13500 sudenly after 6200
Any help ?
Thanks.
Hello please post a trigger scope it certainly sounds like you have a trigger either set incorrectly or wired incorrectly
Oh yes sure i will. So thankful for your reply. I am hoping will get somewhere from here.
i have the datalog and map from last time
i somehow lost the scope csv and image file
will try to make another one when the car in the garage
I CANT UPLOAD THEM
it says null file
dang
this is the logs
  • cut-7200-rpm-2.csv
  • cut-7200-rpm-3.csv
  • cut-7200-rpm-4.csv
  • cut-7200-rpm.csv
Heloo anyone there
sorry a csv file is useless to me to see what is happening i need a llg file if you have trouble it may be best to ask the haltech tech support to log in remotely to check for you i think
Regards Ross
How to make an llg ? With what aplication ?
Anyone else here can help me ?
