Bosch me7 ecu connector terminals
Control de impulso
3340 Vistas
Anyone have the part number for the terminals used on the Bosch me7 ecu connector?
it’s the 81 and 40 pin connectors, I believe they are tyco brand, but I’ve looked everywhere and can’t seem to locate the terminals I need.
photo of connector attached
thanks!
That looks like the connectors (81+40) used on the MBE 9A9 ECU. I have a brand new connector set I would sell if you would like to see if it will work with your Bosch ECU. Just send me an email, ferg@veracitydata.com
Hello, for those connectors the terminals are a proprietery Bosch article named BMK 0.6.
The Bosch part number for 0.35 - 0.5 mm2 is 1 928 498 000 and for 0.5 - 0.75 mm2 is 1 928 498 001.
There are also BMK 0.6-D terminals which are box shaped. However, as far as I am aware they are not meant for the 40+81 connectors. I have added a pdf with a technical assembly drawing for reference as well.
Hopefully this helps.
  • A928000321-DEEN-AGZ-001-004-23-1-SAP-Status-40-Labor-F15-Change-92J14477.pdf
If it really is a BMK 0.6 series, those are available from Ballenger Motorsports in the USA:
https://www.bmotorsports.com/shop/product_info.php/products_id/2245
