NOS Purge Solenoid
Control de impulso
1290 Vistas
Hi Guys,
I have attached 2 pictures of 2 seperate ways I have intended to install the nitrous purge solenoid. Intended use will be for quick spool but will also be left on after on occasions.
can I mount both ways and it won’t matter or is the more direct option ( no T peice ) a better idea to stick with.
cheers
I can't see there being any significant difference in performance.
