Rywire P14A PDM With Fueltech FT600
Control de impulso
2495 Vistas
Over the weekend I created an excel spreadsheet on how I want to wire up my Fueltech ecu, sensors, and pdm unit. However, I'm having trouble trying to figure out if i can power all of the 12v sensors off of the pdm unit that I currently have. Hopefully someone can tell me if it would be possible to power all of these sensors off of the pdm and which pinout I should wire them to. Also, if you notice anything I pinned wrong or have a sensor going to the wrong pinout then I would appreciate it if you would let me know. thanks
The setup I am planning to wire this in is a 4 cyl rwd drag car.
Rywire PDM Webpage
Rywire PDM Pinout Diagram
Fueltech Ecu Pinout Diagram
  • P14-FUELTECH-WIRING-DIAGRAM.xlsx
