Tune issues with haltech
Control de impulso
2202 Vistas
i have had a couple of tunes done on my holden 355 t56 manual vs ute its fitted with a haltech platinum gm sport ecu. Each tune thats been done has had differing issues with tune and how driveableit is after. I have attached a copy of the tune files for u to view.
The phil tune was too rich and made cruising impossible but was good under full load.
The barry tune is good at cruising but under full load especially low rpm full load it can occasionally ping.
The barry altered has been me trying to smooth the tables and get better cold start settings as it stalls out if u dont give it any throttle after it fires.
Any help would be grestly appreciated
  • barry-355-tune-altered.zip
  • barry-355-tune.zip
  • phils-355-ute-final-tune.zip
