k24 main and rod bearings clearance for mild turbo build ( 500-600 hp )
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
1839 Vistas
What would you guys recomend for mild turbo build on Honda k24 ? block will be sleeved forged conrods and pistons.
Would the standard bearings be good enough ( they are sold by grades wich makes setting oil clearences very easy )
and which oil thicknes to run in that engine.
Did you have any luck findind the numbers?, I'm also bulding a similar project.
I'm a fan of stock Honda bearings, but others may feel differently.
