Launch Control with no speed inputs
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
1573 Vistas
I was tuning a customer car today, he does not have any speed sensors on the vehicle. We are trying to set up launch control, but I am only seeing speed based controls for launch control. is there a way to deactivate the launch control based on time or throttle %?
What ECU?
oh, sorry. Link G4+ GTR
Since it's the G4+ did you follow along with the worked example? I think that may help.
A clutch switch is the other most common alternative. Watch the worked example and you'll see how this can be utilised.
