wide band meter
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
1246 Vistas
is a wide band meter the o2 sensor?
Yes, essentially it's a gauge that indicates the mixture (Lambda, EQ Ratio or AFR) based on reading from a connected O2 sensor.
