Choosing the correct coil spring for auto cross
Crear hilos
Módulo relevante: Certificado > Solicitar certificado
421 Vistas
Most of my racing is Auto Cross with that said. How do you go about choosing the correct coil for the shock car set up. Is there a difference when setting up a road course car to an auto cross car?
There is a lot to be learned about autocross suspension setup (especially springs / shocks) from this website:
https://farnorthracing.com/autocross_secrets5.html
Thanks Ferguson!
It's going to largely depend on the characteristic of the course you're running on - especially if it's bumpy and/or rutted, and the vehicle. Oh, and budget!
For the most part, I would expect you to be traction limited, so a softer sutup may be in order, to better follow the track surface, possibly with a longer spring to lift the ride height to help avoid drag from berms or deep rut?
FWD or RWD, and have you a LSD or welded diff?
