Ecumaster PnP lotus 2zz
Discusión fuera de tema
1507 Vistas
Hello
I cannot get the ecu to read my analog input 2# voltage , it always read 0.88 volt. What should I do? It is configured as input to switch on AC clutch.
What voltage do you measure with a voltmeter or oscilloscope? Is this different if the ECU is not connected? Does the A/C clutch switch actually work? Is the ECU providing a pullup resistor to some voltage source?
If using a classic, you'll need to wire in a pullup resistor, or use Cam #2 input and activate it via the software. If using a black, you only need to activate the pullup via the software! If this is already done, check for wiring issues.
I noticed that my analog input 2 is connected to fuel level sensor that is why it is constant. But I dont know which pin is connected to ac switch
Cam #2 is always active
