RB25DET Noisy Lifters Sound
Discusión fuera de tema
2864 Vistas
Hello everybody
i just finished my engine rebuild
RB25DET 1st
CP Pistons
BC Rods
ACL Bearings
N1 Oil Pump
N1 Water Pump
HKS TO4Z Turbo
Tomei Poncam 256
Tomei Valve Springs
ID 1000cc Injectors
AEM V2 Ecu
running 1.2 bar of boost around 520whp
i have a problem with hydrulic lifters nosiy tick sound i use mobil one 0w40 oil
i dont change the lifters still the old one what i can do buy a new oem lifters or change the oil or bleeding the lifters
Some people have reported issues with hydraulic lifters with a larger cam profile, even if the poncam is quite mild. Did you happen to fit an oil restrictor in the block during your build? That is a potential issue if you're retaining hydraulic lifters. Alternatively it's possible that your lifters are in need of replacement. I'd definitely try an additive first to see if that gets rid of the problem. It's not a solution but may buy you some time and can help confirm the lifter is your issue. In the 4G63 we found the Proma MBL8 additive to be almost like magic - pour it in and within 30 seconds the engine would be silent.
