RX7 Stock Connectors. X05 & X14 Connector Identification help
Discusión fuera de tema
1734 Vistas
I am looking to find out if anyone can help me find the part numbers for these 2 connectors. I have looked on Octopart, Mouser etc... Can't figure out which one they are. Any help would be appreciated. I need to replace these and need the pins too.
Also Color does not matter. I have the Grey one in white as well... and the white one I have in blue as well. Function over form in this case lol.
94 USDM RX7 (FD3S)
Brand - Part Number - Links - etc would be amazing
Thanks - Paul
Thanks! The Miltilock 070 series is winner
No probs, I dig what you guys do with bringing FDs in the States back to life.
@M:EP thanks. We try and do it with pride and quality. I found the connectors thanks to you setting me on the right path. What was confusing me was the aftermarket connector I was starting the search with. Once you set me on my path I looked at the stock harness and saw that the rear of the two connectors were the same.
Thanks again and thanks for the kind words. We strive for excellence.
Paul @ IRP
