Souriau supplier in the UK
Discusión fuera de tema
1359 Vistas
Hey guys,
I use Deustch normally but a customer has come to me with some Souriau 8STA connectors he has salvaged from a damaged harness which he wants to use on another project. I am struggling to find a good supplier for Souriau connectors in the UK - essentially I need to buy some contacts and insert/extract tools for these connectors - I can't find anything searching using the contact part numbers I've pulled out of the Souriau datasheet - 8599-0704MJ & 8599-0708 900 for the 16-20awg pins & sockets. Can anyone point me in the right direction?
Cheers
Alex
FC Lane is a very big Souriau Supplier in the UK.
That being said, 8STA and Deutsch Autosport are compatible so you can use Deutsch contacts as well in the correct sizes.
