BMW dme tuning/editor software
2893 Vistas
Hey guys,
what is every one using to tune the bmw dme(ecu)?? I see a lot of people in other forums are using tuner pro for software editing and galletto and Jm garage flasher for uploading but I am very curious as to what the performance shops are actually using to tune these cars. I believe kess has something available but I’m not familiar with them. I’m use to HP tuners. Any help/info would be greatly appreciated. Thanks in advance!
I know Ecutek is common and compatible with a lot of DMEs bmw uses. WinOLS seems very comprehensive as well. I see both of these used in tandom with tunerpro often. You'll just need to find the proper definition file.
