Andre never hitting rev limit on dyno?
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
1838 Vistas
as the title say, in the videos I have seen Andre never hits the Rev limit of the car.
Is that because he lifts the throttle before the rev limit or is the dyno set up to break the rolls so the car never gets to limiter?
best regards
kent
You can use the dyno to hold a steady rpm or to ramp rpm, like from 2000 to 6000rpm.
Hey Kent, on our mainline dyno we can set a start speed and end speed for a ramp run. When the dyno reaches the end speed it will actually start to reduce the speed back towards the start speed again. In this way we don't need to rely on the rev limit to let us know when w'eve reached the end.
