DIY Curly Cord
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
3516 Vistas
Has anyone got any tips on making up curly cord using DR-25? :)
I think you should just source a retractile cord with chemical resistant, abrasion resistant, elastomeric coating. It doesn't need to be the DR-25 brand to be perfectly adequate.
I know this isn't DIY, but if you really wanted it, I would contact someone in the business like this:
https://www.northwire.com/custom-cable-solutions
Thanks David.
I know there are various cords available, but I have seen them before with DR-25 sleeve and I was keen to have a go.
Just curious if anyone has done it :)
Yes, it's easy to do.
Just put DR-25 around your concentrically twisted wires, don't shrink it, wrap it around a about 10mm diameter rod which itself is covered in DR25 (not really necessary but works nicely) and then shrink your DR25 starting from one end, short sections at a time. Takes some practice but is easy to do.
Thanks Christoph, I’ll give that a try :)
Invert the coils after cooling for maximum effectiveness
