e36 drift monster m50/m52/m54/s54 frankenstein
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
3372 Vistas
Hello everyone, my name is Hristo im from Bulgaria living in the UK , im not new here but its my first time writing, i have a small garage fixing and upgrading BMWs mostly .
So more about my project
1998 m52b28 LHD bmw e36 coupe
for now ill keep strictly to engine upgrades and tuning
i have a spare m50b25 non vanos lying around
so i took off the cams and sprockets and installed them into the m52 to delete the vanos
for now thats going to be the only engine work i will do i want to test its limits
i have a megasquirt 3 integrated into the original ECU box
running stock m50b25 non vanos wiring loom
ill be runing gt3076 china
cast log manifold bottom mount
s54 oil filter + 25 row oil cooler
bosch 044
custom 6 an lines + surge tank 2ltrs
sytec fuel pressure regulator
custom fuel rail
siemens deka 630cc long injectors
innovate lc2
turbosmart ultragate 38mm
any tips or advises will be appreciated, it will be running pump gas TESCO 99 octane best u can find UK, we dont have any access to e85 so im considering water/meth i want to see how it behaves at 7psi (wastegate pressure) and how long it will last .
later i will start uploading some photos :)
Welcome to HPA Bimmerboy92, You'll need to ask specific questions to get answers on here as tuning is such a broad subject when people don't know your build.
Tesco99 is a high RON fuel but you need to be mindful that it has an ethanol content (I can't remember the exact amount) which makes it such a high RON fuel so if your car has been sat for a while with it in the tank then you may suffer knock as the benefits of the ethanol have been negated by the moisture that it has absorbed from the atmosphere
Thanks bud , im aware of the ethanol content maybe thats why UK tuners use it and prefer it to Shell , ill see how it goes i hope at 7 8 psi i wont be really knock limited 10.5:1 compression btw stock
And another quick question do you guys recon 38mm turbosmart ultragate will evacuate enough gasses to keep me away from boost spikes at those low pressures . There is a photos of the position looks like its in the direction of the flow on almost all runners
