Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
Good day guys,
We d engine swap from K24a3 -K24Z3, the difference between the two is the Crankshaft position sensor location , A3 is located near the harmonic balance and the Z3 is located at the back near the flywheel, is there any setting I can change on hondata software to edit the trigger or does someone have a base map I can start with? Any advice?
Thanks in advance
Hi there,
K24z3 is from accord or acura tsx? as the compression ratio is different. 10.5 for accord and 11: 1 on acura. Check on hondata for these cars they range 2008- 2010 if im not mistaken and you could find a base map for your k swap.
