Nissan 350z oscillating rpm, first startup.
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
1902 Vistas
Hi there,
This is a crosspost with the link forum.
I switched ECU from Haltech to a Link 4G+ on a previous car of mine. Car ran fine with the exception of oscillating rpm's during idle. Never found the time to fix it . Now i have another car, also a Nissan 350z with a new build on it, and using the same Link ECU. I created a new map which currently is still bare but just enough to start up. Right after startup i see the same oscillating coming back. Maybe you guy's know whats going on? I have the assumption that the idle base position table is not holding the right values.
Another question which just popped up: for this car i'm using a fuel pressure regulator which is connected to MAP. Can i use traditional fuel equation? im trying to figure out which works best for me. Coming from Haltech where i have to input the fuel pressure and tell the ECU its a MAP referenced fuel pressure. I hope you can advice me?
Kind regards!
attached the map and log file.
  • 350-coupe-new-08-05-2018.pclr
  • Log-2018-05-12-114237-am.llg
