C16 timing AFR with boost di engine
Diseño y optimización del sistema de frenos
Discusión y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos
2531 Vistas
hi guys,
i was tuning one of our race trucks its running on c16 its the new gm di engine 5.3 i am running 21 psi of boost and 21deg timing i also have 8 jets of direct methanol also used as fueling since we dont have any other solution for fueling ......
truck made 1100whp on the dyno at 13.3afr if i go down to 12.5 afr it would drop to 980whp with same timing and timing mark looks like it can take 4 deg more ...if i lean it to 13.3 timing mark moves towards the middle of the strap and gains 120whp
Do you have a specific question?
I'm not 100% sure what you're wanting to know here? A big consideration with this setup is that you're using two fuels with vastly different stoich AFRs (14.7:1 and 6.4:1) so the stoich AFR of your overall fuel mixture is going to depend what proportion of the delivered fuel is methanol and C16.
