3 bar map sensor
Entendiendo AFR
390 Vistas
hi looking to see what 3 bar map i need for a turbo 5.3 ls engine running a holley terminator computer any thing would help
Here's a reference site to check out.
https://www.pcmofnc.com/2020/03/12/gm-map-sensors-1-bar-2-bar-3-bar/
Hope it helps.
i will check it out thank you
