Battery Isolators / Kill Switches
Entendiendo AFR
1961 Vistas
I would like to start this thread to discuss about battery isolators. Let's discuss about the models available on the market, how they differ from each other and about the experiences we had with them.
I will gather some info about the ones I know and put them all here:
MSEL:
MSEL sells two versions, Clubsport and Professional:
https://msel.co.nz/msel-solid-state-master-relay-club-battery-isolator/
https://msel.co.nz/msel-solid-state-master-relay-professional-battery-isolator/
HP Electronik HP8480:
https://motorsportelectronic.com/Hjem/hp8480
ECU Master:
Club:
https://ecumasterusa.com/collections/power-management/products/ecumaster-battery-isolator-club-m8?variant=39386475593892
M8:
https://ecumasterusa.com/collections/power-management/products/battery-isolator?variant=35810728411300
Radlok:
https://ecumasterusa.com/collections/power-management/products/battery-isolator-radlok?variant=36694863282340
ECUMaster have a version with Radlok connector. I used Radlok in the past but only at the bulkhead, so I have no experience with that product.
https://ecumasterusa.com/products/battery-isolator-radlok
What about the Cartek isolator? That's what I run; https://www.cartekmotorsport.com/battery-isolators/
