BMW B58 wiring diagrams and pinouts
Entendiendo AFR
1839 Vistas
Hi,
I have been assigned the task to wire-in a standalone ECU on a B58 engine and fit it into a race car.
The engine came with the standard engine harness, of which I plan to use by simply making an adapter harness from the new ECU to the OEM engine harness.
I was wondering if anyone might have the pin-out of the OEM sensors, coils, electronic wastegeate, MAP sensors, etc. , and any idea on how the electric thermostat works?
Thanks.
I get all my diagrams and technical data from the TIS: https://www.newtis.info/
send me an email so I can send you an invite link to register: mpr.servicios247@gmail.com
Thank you. Mail sent.
