cheat cheat sheet
Entendiendo AFR
Módulo relevante: Habilidades prácticas de WinOLS > Configuración de WinOLS
1282 Vistas
Hi andre is there a pdf or downloadable link or chart of the factor cheat scaling dont seem to see it in the course structure
thanks
Our apologies for the delay in response. I've been working Pikes Peak Hill Climb and Andre is on vacation. Andre will return next week and I've left him a link to this thread so he will be in touch soon.
Thank you for your patience,
It's in the related resources section if you scroll down within the course. I've included a link for easy access:
https://www.hpacademy.com/dashboard/courses/winols-mastery-map-identification-and-editing/winols-tuning-basics-8bit-16bit-32bit-and-floating-point-values
