Dual ignition/Fuel Map for K20 VTC engine
Entendiendo AFR
2366 Vistas
Hello
I need your support
Am Using Mosoon ECU G4+
I am tuning my car on a single igni/fuel table. for the VTC/VVT engine, I would like to implement for duel ign/fuel when the VTC/VVT cames hit.
Go to >fuel corrections>dual fuel table. Set the mode to dual table, set the table 2 activation to whichever aux output activates your VTEC. Fuel table one will be active when VTEC is off, Fuel table 2 will be active when VTEC is on.
thank a lot for the best support Adam and HP
