dynocom dyno
Entendiendo AFR
2495 Vistas
is anyone familiar with the dynocom dyno
if so have a bit of trouble doing load test on the dyno
Sorry Marcel, I haven't used a Dynocom so can't be of any help. Hopefully someone else will be able to help you though.
so am I, I hope someone chime in
I'm just chiming in to say we see you, but unfortunately I can't help with this as I haven't used a working Dynocom dyno.
Hopefully Dynocom support can assist you?
