Emtron KV8 ECU
Entendiendo AFR
2331 Vistas
Does enyone have any knowledge in tuning Emton ECU ? Im in Adelaide Australia with limited tuners using this ECU. Any pros and cons would be helpfull. Thanks
Have you got any specific questions? We're not personally using the Emtron here at the moment but I have a good friend who is well versed in the system. Alternatively I'd imagine Scott @ Emtron could point you towards a tuner in your area.
