How to depin Conxall Maxi-Con-X connector ?
Entendiendo AFR
1409 Vistas
Hi guys,
I'm note sure if this is the right place to post this thread.
I need to depin Maxi-Con-X connector that Radium Automotive use with their FCST surge tank. The connector part number is 13182-7SG-321. Did anyone try to depin it?
Thanks,
Hello! I never use this type of connectors, but I found this on page 35.
I hope that is what you were looking for.
Best regards,
https://www.mouser.es/datasheet/2/393/conxall_catalog-488.pdf
