nismo 740cc injectors
Entendiendo AFR
1577 Vistas
how can i find what the settings shoud be ie the latency
https://injector-rehab.com/shop/lag.html
I have found this info, they are listed in that table... no idea if it is reliable info, but probably would get you in the ballpark.
