Rolling launch control
Entendiendo AFR
1903 Vistas
I have a 2jz-gte vvti , Motec M150 with John Reed Racing package, the package is based on the GPR package , I have anti lag and launch control in race functions but I don't have rolling launch , is there a way around it to make rolling launch control? Thank you
What do you think would be different in a "Rolling Launch" vs. the Traction Control? Are you really talking about Rolling Anti-lag? Here was a post on the MoTeC support forum regarding this capability in GPR:
https://www.motec.com.au/forum/viewtopic.php?f=53&t=3320&sid=f2e8d823422b0e7916b34f1cc18fd868
Yes I meant rolling antilag, thank you so much for the info.
