Stock Can Am Maverick X3 tune files
Entendiendo AFR
855 Vistas
Does anyone have any stock Can Am Maverick X3 tune files they can share?
I recently helped a buddy (actually, my business partner) install a Whalen Speed kit (intercooler, BOV/pipes, race exhaust, upgraded fuel pump, and WSRD tune via the included DynoJet PV3), and the tune is locked with a password so I can't look at it. However, the kit we got basically is just the parts off an X3 RR (the intercooler and fuel pump are stock parts for an RR) so I presume the WSRD tune file is likely very similar to the stock RR tune. That's really what I'm after, a stock RR tune file to look at and compare to the stock tune file I pulled from the car before we did the kit. This way I can see what is different and this should help me in my learning process.
Since I really want to get into tuning these UTVs, getting stock files to play around with would be very helpful to me in the learning process. If anyone has any they can share, or advice, please do. Thanks!
Dynojet seems to have stock UTV tunes available for download on their website. Have you checked to see if that one is there?
I did try their site, but it seemed that you need a .stk file to upload first before you can access any tunes they have. Unless of course I'm doing something wrong...I'll have to pull the stock X3 tune file I have on the PV3 and see if that does anything on their website.
From what I remember reading on their site, the .stk files gets access to the tune files they have for that specific model only. Meaning, if that is correct, that I can't get any tune files for a Turbo RR since I don't have a stock file for it. The machine my buddy has is a base DS (120hp version).
Ah gotcha thanks for the info. I haven't used their product on a UTV.
Have you contacted Dynojet? Maybe they just don't want competitors to be able to download EVERY file off their website, but they'll send you a file.
Or perhaps WS has it?
