Supercharger on diesel
Entendiendo AFR
1543 Vistas
What would be the advantage and disadvantages on supercharger on an diesel as haven seen it on factory vehicles
I'd suggest posting this in the diesel forums. My 2 cents is it's because diesels generally use a fairly narrow rpm range and a turbo-charger is much more efficient for that, and they can offer a greater pressure ratio (boost) than most superchargers.
