tuning on the road
Entendiendo AFR
1157 Vistas
Hi, if i am tuning a car on road/racetrack and i m adding more ignition advance to the map and i notice a knock. Does the knock damage the engine if i react on that properly right a away? whit properly i mean, lifting up my feet from a gas pedal, stopping the car and retard the timing.
hello there is not much chance that a small amount of knock over a very short time would do any damage at all unless it is a rotary
