2jz ecumasters black idle question
Escaneo 3D práctico
Discusión y preguntas relacionadas con el curso Escaneo 3D Práctico
1523 Vistas
A buddy of mine has a built 2jz with brain crowder 272 cams he got tuned and asked me if I was able to make it sound lopey at idle so I told him I would try I was able to get it to do it some by messing with the idle correction table and make it have bigger timing swings but it’s like it wouldn’t swing fast enough to lope correctly it was more of a slow lope I guess you would say
he compared his to other ppls with the same cams his car sounds stock and others are choppy so he wants the chop chop lol
any ways how would I go at doin this correctly so it sounds nice and choppy how he wants it?
You can try lower idle rpm and leaner mixture along with less ignition timing.
