Output offset question. EcuMaster
Escaneo 3D práctico
Discusión y preguntas relacionadas con el curso Escaneo 3D Práctico
1043 Vistas
Hello, My car is a Fiat 500 Abarth 2009 135Hp.
And I bought the black EcuMaster plug and play kit.
I have already configured the Engine TDC with the spot light, the car starts all ok. But my question is in the Outputs ignition module, I have an offset that is numbered 2. And I can't understand what it means. If I set it to 0, the car doesn't work.
I'm attaching the image so you can help me make sure I have everything configured correctly and I marked this number 2. Thank you
What this does is offset the order by the number in the field. So in your case the order effectively becomes 4-2-1-3, this is for getting the trigger settings correct.
Same order as any other 4 cylinder but just starts in the middle.
At one time the most you could have in the "trigger offset" in ECUmaster was 60*, this was their method of setting timing, actually quite nice for certain applications.
If you have it timed correctly as these settings are then I wouldn't worry about it.
