Any Experience with Motorsport Electronic's line of ECUs?
Fundamentos de fabricación para deportes de motor
227 Vistas
Hi all, I was curious if anyone has ever used any of the motorsport electronic's line of ECUs. A coworker of mine bought a ME360 to run a K24 swapped Z32 and I am helping him with the build, especially with wiring and tuning. The software looks good, but just curious of anyone's experience, good and bad, and if HPA is planning on doing a worked example with this line of ECUs.
I'm a dealer for them and have been using them for a good few years now.
The ECU will run the engine fine, make sure you open the tabs fully in the software both toward and downwards. I'm not sure if it's the resolution of my laptop they don't display everything when you first open them up
