LML Duramax
Fundamentos de fabricación para deportes de motor
1630 Vistas
Looking to build an "off-road" diesel. I have just purchased a HP Tuner Pro set up with 2 credits for the truck and am looking for a tuning file that will prevent the truck from going limp / throwing codes. Keep in mind, I am very new to using any tuning applications / tuning in general. I have spoken to Motor Ops and the only HP tunes they have is for L5P Duramax's. I have just ordered a WC y bridge kit w/ down pipe and currently looking for a 5" exhaust. The rotating assembly is stock as well as the camshaft, turbo, and fuel system. The only tuning stuff I can find for an LML is all EFI live.
I'm in the same boat. Does anyone have any suggestion or help with tuning Diesel's. Not looking to bypass or violate anything.
I've purchased the diesel tuning package from HPAcademy!!
LML tuning help also
Thanks guys
Hey Andrew im wondering if you ever figured out how to disable the dpf and egr system
H&s minimax, they have a flash tune to bypass it. But are not sold anymore. Best to look online for a used one.
