C125 - Volvo EHPS Pump Control
Fundamentos de la aerodinámica
Discusión y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
837 Vistas
Hello all,
Partially copied from the MoTeC forum:
I've just started looking into this, but thought I'd ask here as well.
I've attached one of the many versions of code I've found to do it: https://github.com/jssteinke/Volvo-EHPS-Pump-Control/tree/main
Has anyone tried to do this with the C125?
Thank you!!
doesn't seem unreasonable to achieve with a c12x dash.
I know of someone who has done it with a PMU, so with an SSR and Motec dash it seems doable.
I have done this with a Link ecu for some users before. I dont have time to set up a dash config for you, but thought I can give a couple of clues to make it easier:
The quoted transmit frequencies arent critical, I used 2Hz for the keep awake message and 50Hz for the assist level message and it worked fine.
The keep awake byte 0 is quoted as a "counter" with values 0x00, 0x40, 0x80, 0xC0, if you break this down to binary this is actually just 0,1,2,3 cycling in the 2 most significant bits. To generate the 0/1/2/3 in the link I just used a timer that reset every 2 seconds (since we are sending the message every 0.5 sec) and multiplied the time by 2. So at 0sec it sends out a 0, at 0.5s it sends out a 1, at 1.0s it sends out a 2, etc. The rest of the message I just used static values to match the example message.
For the Assist level message I had the first 6 bytes static to match the example message, then byte 6&7 are your requested assist level. 0 is max assist and 6000 is min assist. In the Link I used a 0-100% signal (from a 3D table of speed Vs potentiometer), then in the CAN message just multiplied that by -60 and added (offset) 6000, this converts the 0-100% into 6000-0
