Tuner from France !
Fundamentos de la aerodinámica
Discusión y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
632 Vistas
Hi Folks :)
I'm Alexis, a tuner from France.
I own a little Garage when i do all the mechanic stuff + lot of modification.
For a moment, i bought my file at compagny, but was a lot disapointed..
I learned how to perform DPF - EGR -ADBLUE by myself, get the Alientech courses, but you learn to perfom mode by % only with ECM titanium
So i bought stageX and find a crac*** winols to check all my bought tune, and find some stuff, but not what i wanted.
I learned by myself to check all the torque to iq maps, soi, eoi ..Etc.. but didn't manage to do some good stuff like what we can see here in France at Br Performance or so.
So here i am, to fully learn and understand all the thing that i have missed :)
I personnaly had a lot of moddedcar, but at this moment i have :
- Fiat coupé 20V turbo, that i tuned by someone but the engine blow off .. so i rebuilt one, and i'm on the way on transforming the car from 2wd to 4wd, maxxecu and full wiring by myself (and i hope, a full tune)
- Espace iV 3.5 V6 (full stock for the moment)
- Ford scorpio swapped with a vq35de, project still on the way, like the Fiat Coupé
- Audi A4 1.8 20VT 150hp, i'm looking for a 4wd configuration and puting big injector, turbo ..etc.. and running a speeduino for the fun of it
- Peugeot 306 1.8 16v, that i may put a turbo on :)
That's all, but as all garage owner, i'm missing time for my project car ^^
I have some illness that i can't cure, so wish you all the best and take car of you, hope to see some of you at car's show :)
Alexis
Hey there Boulmay, welcome to HPA mate!
Nice mix of cars you have there! And you have the best kind of illness we reckon haha
That AWD Fiat project sounds awesome, solid choice on the MaxxECU too 😎
Time is something we all struggle with, and it is for sure worse when your garage is also your place of business. Hard to step away from the work that pays the rent eh!
Material wise note we don't cover how to remove the likes of your DPF or EGR, we only cover the tuning side of things. The tuning process you need to understand is independent of those however. If you have them you need a few considerations which we cover, but without there is just less to worry about which is the right way around for you.
I hope you enjoy the MaxxECU content as well when you're ready for it. What ECU are you using on the Ford Scorpio project?
Hi Taz :)
For the DPF, EGR parts ..Etc.. don't worry, i'm already ok with this part :)
Will for sure appreciate the MaxxECU content :)
For the Ford Scorpio project, for the moment, i'm doing a full swap (electrical + mecanical), so i will run the stock ecu.
My wife is already seeing the turbo on the vq35, so i may switch to a standalone ecu when time will come :)
The AWD Fiat Coupe project will be the hardest one .. very hard to find information for it, hard to find parts ... But, with the waiting GTX28 gen2, will be awesome to run ahah :)
